How to know Es(MV/m) along RFQ length ?
Posted: Wed 17 Aug 2022 08:49
by sarvesh
Please suggest how to plot Es(MV/m) using RFQDesign or Toutatis ? Which generated file has such informations?
Re: How to know Es(MV/m) along RFQ length ?
Posted: Wed 17 Aug 2022 09:54
by RomualdDuperrier
in the multiparameter plot, the evolution of the kilpatrick value is described. This plot can be exported in multiple image format but not in acsii format like .csv. Conversion from kilpatrick to MV/m is possible via the Objectives tab. Also, I remark that it could be convenient to have the possibility to export the plots in .csv and to let the user setting the unit for the peak field. I will definitely think about it for future versions.
Posted: Wed 17 Aug 2022 14:51
by sarvesh
We need not only Es but also Plot of B along RFQ length so that we can generate equivalent file in PARMTEQ and benchmark the results. Please suggest. PARMTEQ needs along Z (not along cell), the evolution of B, Phase, Modulation and voltage. Please help how to generate equivalent PARMTEQ file.
Posted: Wed 17 Aug 2022 16:12
by RomualdDuperrier
Yes, so exporting all plots in .csv should make it. If you are hurry, note that running Toutatis with the .inp produced by RFQ Designer will provide all you need as Toutatis can export all plots in .csv.
Posted: Wed 17 Aug 2022 16:44
by sarvesh
What is the name of that file? Do we need to give any option to generate that file in the toutatis command? I am not generating any .csv file after running toutatis. I can get Phase, Modulation and voltage nut no B in TRACEWIN file generated out of Toutatis run? I am running Toutatis from command prompt.
Posted: Wed 17 Aug 2022 17:43
by RomualdDuperrier
you need to plot your data of interest, then you hae to run the GUI version of Toutatis 2.0. In each plot window, you can right click and export in various format like .csv.
