I got this message, see attached.
What is the reason that I can't use "part_rfq.dst" as the input distribution?
It might be related to another problem that I have.
Jonathan
"Don't use 'part_rfq.dst' as input distribution file" message [SOLVED]
jonathan dumas - Neophyte
- part_rfq.png (57.96 KiB) Viewed 11921 times
Re: "Don't use 'part_rfq.dst' as input distribution file" message [SOLVED]
Dear Jonathan,
This specific file name "part_rfq.dst" is used by the code itself in the calculation directory and so your input file would be overwritten. So rename it or move it.
