exporting data from a phase space plot
Czech RepublicFrancescoS
Czech Republic (cz)
Czech Republic
Post by Czech RepublicFrancescoS »
Goodmorning,
it might be a stupid question, but I cannot figure out a way to export the data of the density curve in the phase space plot.
Is there a way?
I mean the two lines point with an arrow in the attached image
THank yuo in advance
Czech Republic (cz)
Czech Republic
Re: exporting data from a phase space plot
ok, I think I have figured it out.
I need to open the phase space in PlotWin and save the density file .den
This file has many sections, if I plot the Vertical/Horizontal 2D projection [Y/X], for example, I think I have what I need.
Am I correct?
Last edited by Czech RepublicFrancescoS on Fri 21 Jun 2024 07:20, edited 1 time in total.
Dear Francesco,
Yes it"s perfectly correct, but you can also do that directly from TraceWin outputs.
Czech Republic (cz)
Czech Republic
Right, I just noticed the .den saving option when doing it fomr the phace space plot in TW.
basically PlotWin is not necessary
Thanks
F.
Czech Republic (cz)
Czech Republic
good morning again,
I have noticed that in the den file the section appears more than one with sliglty different numbers
For example I have two times Vertical 2D projection [Y].
Is this because I am saving the den file in a plot where I have 4 phase spaces (X-X', Y-Y', X'-Y' and X-Y)?
I guess so, and in the density file I have all the projections of these 4 plots.
If I am guessing right, then it would be easier to only plot X-Y and save the .den file so I only have the space density profile.
does it makes sense what I am saying?
Yes, the *.den file could contain the same projections several times, depending on the phase spaces drawn.
This has been corrected in the latest version.
Czech Republic (cz)
Czech Republic
I see, so I'll update my version.
thanks a lot
