Since I upgraded Fedora to version 40, the GUI doesn't appear. There's no error message.
I ran it with valgrind and the options "-s --leak-check=full --show-leak-kinds=all". The log file is attached.
Emmanuel
No GUI with Fedora 40
Re: No GUI with Fedora 40
Hi Emmanuel,
As usual, what doesn't work for you works for me, making it difficult to correct what does work.
I'd like you to post the file where the results of the following command will be stored :
sudo yum list installed > listinstalled.txt
Thank you in advance.
Emmanuel
Emmanuel
Dear Emmanuel,
Voici le fichier demandé
