Could you please make the resulting quadrupole values from the lattice command conveniently available? I am only able to find those values in the self generated .dat file. A file layout similar to the self generated xx_CC.txt file for fieldmaps would be great.
Quad result from LATTICE command
Re: Quad result from LATTICE command
Dear Wia-Ming,
I don't understand your request: the xxx_CC.txt file contains the values of the quadrupoles (hard-edge of FIELD_MAP) modified after the lattice command or any other command capable of modifying them.
- Skilled
I only found field map and hard edge dipole in the xxx_CC.txt file. There is no hard edge quadrupoles.
- Skilled
Below is an example:
; Structure file
DRIFT 0 100
drift 10 10
lattice 4 1
set_adv 85
quad_ele 10 10 10
drift 10 10
quad_ele 10 -10 10
drift 10 10
quad_ele 10 10 10
drift 10 10
quad_ele 10 -10 10
drift 10 10
quad_ele 10 10 10
drift 10 10
quad_ele 10 -10 10
drift 10 10
lattice_end
DRIFT 0 100
END
Below is the xxx_CC.txt file:
Fichier TraceWin:
Particle name: Proton
Particle mass: 938.272 MeV
Particle charge: 1
Beam intensity : 0 mA
Input energy: 1 MeV
Output energy: 1 MeV
; Structure file
DRIFT 0 100
drift 10 10
lattice 4 1
set_adv 85
quad_ele 10 10 10
drift 10 10
quad_ele 10 -10 10
drift 10 10
quad_ele 10 10 10
drift 10 10
quad_ele 10 -10 10
drift 10 10
quad_ele 10 10 10
drift 10 10
quad_ele 10 -10 10
drift 10 10
lattice_end
DRIFT 0 100
END
Fichier TraceWin:
Particle charge: 1
Input energy: 1 MeV
Ok, I see now. It's fixed.
- Skilled
Two more issues:
(1) I also realized that some RF electric field maps (flag "100") would appear in the CC.txt file, but some don't. Could you make all of them appear?
(2) Electrostatic field maps (flag "1") would appear in the CC.txt file as FIELD_MAP_CAV and have Input_cavity_phase.
Two more issues:
