Lattice command
Indiamahendra2
India
Lattice command
Post by Indiamahendra2 »
Can you explain what Lattice command do, say if i define a FODO with lattice command and i only define the fodo elements but not keep with in lattice command . Then what will be the difference?
Re: Lattice command
Dear Sir, Hello
I don't understand what you're asking. Please be more specific. Some examples ?
Indiamahendra2
India
Re: Lattice command
say i have one structure file like Lattice 2 1 ,drift, quad, drift, quad, drift, lattice_end and another i dont use Lattice command so structure file like drift, quad, drift, quad, drift and transport beam in both how the result is different or what is difference between this two structure file.
can you explain when to use lattice command
Re: Lattice command
Dear Sir,
DIRFT QUAD DRIFT QUAD, normally it's LATTICE 4 1, because your period is made up of 4 elements.
Anyway, this lattice command doesn “t change anything to the simualion in these elements, it just allows the code to know your period in order to calculate the phase advances according to the period you're defined.
Indiamahendra2
India
Re: Lattice command
is lattice 2 2 can be used instead of lattice 4 1
Re: Lattice command
In your case, I don't think so.
