Beam matching
Indiamahendra2
India
Beam matching
Post by Indiamahendra2 »
Hello everyone,
I'm new to TraceWin and have a couple of beginner-level questions regarding beam matching and envelope plots:
When performing a beam matching operation, do we only need to provide the structure file (i.e., the lattice), and not the initial Twiss parameters of the beam? If so, does TraceWin compute the matched Twiss parameters automatically? And in that case, are the matched Twiss parameters the same at both the input and output of the structure?
If the Twiss parameters are matched, does this imply that the beam envelope (spread/width) at the input and output positions of the structure are also the same in the envelope plot?
Thanks in advance for your help and clarification!
Re: Beam matching
Dear mahendra2,
Your questions relate more to knowledge of dynamic beam than to the use of TraceWin. TraceWin can pretty much do anything you want. Perhaps you should take a look at the examples provided, which show a number of uses, in particular how to calculate the beam best suited to a structure.
Indiamahendra2
India
Re: Beam matching
can you suggest me some literature or book or any resources having some more no of example and problem on beam dynamics for practice ranging from basic to advance using all this concepts of element and commands (in a way like problem and solution). which focus more on fundamental of beamline design and optimization. which help me to learn and use Tracewin efficiently.
