Are we allowed to modify variables in batch mode? If not, would you consider offering this?
Thanks.
Modify variables in batch mode
Re: Modify variables in batch mode
This feature does not require any specific rights or authorization - you just need to be able to do it !
wtam
- Skilled
I mean modifying variables in a way similar to element parameters as described in p.15 in the user manual.
Yes, that's what I was referring to. No rights are required to modify variables or element values via the batch command line.
Do you have a specific example, so that I can understand the problem?
wtam
- Skilled
The following is my request.
Here is the lattice code:
variable aaa 100
drift aaa 10
Here is the batch mode code:
TraceWin_noGUI.exe project.ini aaa=50
The above do not seem to work.
variable aaa 100
drift aaa 10
wtam
- Skilled
Also, ele[n][m] does not seem to work with field map for RF E-field, i.e. flag = 100.
I added feature allowing to use VARIABLE as arguments in batch mode.
Concerning problem about ele[n][m]=xxx in FIELD_MAP element, that works on my side, could you be more specific ?
wtam
- Skilled
I confirm that VARIABLE as arguments in batch mode works fine.
Concerning problem about ele[n][m]=xxx in FIELD_MAP element, specifically for RF E-field 100, the 6th parameter seems to have issue.
