Error in the adjust command
FrancescoS - Initiated
Czech Republic (cz)
I am trying to use the diag_size_max but I am having this error:
ADJUST command
Parameter number:0 of element:'DRIFT' cannot be adjust,
it exceeds the maximum number of 'DRIFT' parameters
From -> [ELEMENTS]: get or Set element data
From -> [DIAGNOSTIC]: Plot asjust calculation
From -> [DIAGNOSTIC]: Criteria calculation
From -> [OPTIMIZATION]: Optimi3
From -> [DIAGNOSTICS]: Calculation
The code I am using is below, there are some fieldmaps that are pretty big, I can in case share everything, if needed, but I think the error can be reproduced changing the maps with quads or any other element.
I can place several DIAG_SIZE and the simulation works, but as soon as I add a DIAG_SIZE_MAX I have this error and I don't understand why.
Can you please help?
Thanks
F.
; Structure file
Drift 35 75
adjust 1 1 1 40; 150
DRIFT 63.5338 50
FIELD_MAP 70 120 0 15 -0.90801 0 0 0 B120mmIron
adjust 1 1 7 40; 150 100
DRIFT 40 50
FIELD_MAP 70 80 0 15 +0.9004 0 0 0 B80mmIron
adjust 1 1 2 40; 150 100
DRIFT 123.305 50
FIELD_MAP 70 80 0 15 -0.9004 0 0 0 B80mmIron
adjust 1 1 6 40; 150 100
DRIFT 70.2302 50
adjust 1 1 3 10 30; 150 100
DRIFT 10 50
Drift 1236 50
DIAG_SIZE 1 5 5 (2)
superpose_map_out 800 70.5649 0 0 0 -10.047
superpose_map 0 30 0 0 0 0
FIELD_MAP 70 800 0 50 0.17474 0 0 0 Rog3Blineb ;0.36 riscala da 1.465 al valore di .0448 per i protoni da 60 MeV
drift 95.0334 300
superpose_map_out 800 -70.5649 0 0 0 10.047
superpose_map 0 -30 0 0 0 0
FIELD_MAP 70 800 0 50 -0.17474 0 0 0 Rog3Blineb
drift 22.5167 300
diag_size_max 1 10 10 0 0.01 (1)
Aperture 8 20 0
drift 50 300
Aperture 8 20 0;0.5 10 0
diag_size 1 5 8 0 0.01 (1)
drift 22.5167 300
drift 95.0334 300
DIAG_SIZE 1 5 5 0 0.01 (2)
Aperture 20 20 1; 10 10 1
DRIFT 500 50
END
ADJUST command
Thanks
F.
; Structure file
Drift 35 75
DRIFT 63.5338 50
DRIFT 40 50
DRIFT 123.305 50
DRIFT 70.2302 50
DRIFT 10 50
Drift 1236 50
DIAG_SIZE 1 5 5 (2)
drift 95.0334 300
drift 22.5167 300
Aperture 8 20 0
drift 50 300
drift 22.5167 300
drift 95.0334 300
DRIFT 500 50
END
Re: Error in the adjust command
Dear Francesco,
Unfortunately, simply by replacing your FIELD_MAP with quadrupoles, I can’t see any errors like the one you’ve described.
You’ll need to send me your entire project.
Czech Republic (cz)
Goodmorning Didier,
sorry for my late answer. I have sent you the project with the fieldmaps using WeTransfer.
Cheers
F.
Cheers
F.
Dear Francesco,
Sorry, I haven't received anything !
Czech Republic (cz)
Strange, you have a PM
Thanks
F.
Thanks
F.
A PM ?
Please make a zip file and send me as private message here
Czech Republic (cz)
Yes, I sent you a private message (PM) with the link, and another one now with the zip folder of the project
Dear Francesco,
You have to upgrade your code. This error has already been fixed.
Czech Republic (cz)
ok, I'll do it, thanks
F.
F.
Czech Republic (cz)
Hello Didier,
there is another problem with the new version.
I have this error message:
Following error occurred :
'Part of the beam distribution never reaches the end of the field map!
Try selecting ‘Losses in FIELD_MAP’ option of ‘Simulation options’ of the main page
From->[PARTRAN] : Beam transport in field map
From->[PARTRAN] Library
From->[PROCESS_ENVELOPE] : Run PARTRAN
From->[PROCESS_ENVELOPE] : Run multiparticle program'
OS : Win11 (64-bit)
Gcc version : 4.7.1
User : francesco
Computer : msi
Network : Yes
Free memory : 41.0756 GBytes
Free disk space : 97.2494 GBytes
Handles : 837
Font [8] : 'MS Shell Dlg 2'
DPI : 96
TraceWinVersion : 2.26.0.12
[ Ref_number: 2074-174 ][12]
I did select Losses in Field map but it doesn't change...
OS : Win11 (64-bit)
Gcc version : 4.7.1
User : francesco
Computer : msi
Network : Yes
Handles : 837
DPI : 96
