Colleagues,
I am not able to use w_p_limit twice in a model. For example:
drift 10 10
w_p_limit 0 10
drift 10 10
w_p_limit 0 0
drift 10 10
The above doesn't seem to work in the sense that after the command "w_p_limit 0 0", particles having a phase larger than 10 degree are still considered lost. Any idea?
w_p_limit
Re: w_p_limit
Dear Wtam,
I noticed a kind of shift between command and the element where it is applied, explaining your issue.
I fixed this issue and you can so upgrade your code
wtam - Skilled
Re: w_p_limit
I have upgraded the code. But I think the issue has not been fixed completely. For example:
drift 10 10
w_p_limit 0 10
drift 10 10
w_p_limit 0 12
drift 10 10
w_p_limit 0 0
drift 10 10
The first and second ones will work. But the third one won't work. I think it is a problem with "w_p_limit 0 0", specifically when you put two zeros.
drift 10 10
w_p_limit 0 10
drift 10 10
w_p_limit 0 12
drift 10 10
w_p_limit 0 0
drift 10 10
Re: w_p_limit
Indeed 0 has no effect at all, but first I don't see the point of such a command. If you want to stop the whole beam, there are many other ways and then try 0.0001, it will work.
wtam - Skilled
Re: w_p_limit
I believe "w_p_limit 0 0" means no limit.
drift 10 10
w_p_limit 0 10
drift 10 10
w_p_limit 0 0
drift 10 10
By doing the above, I want to set a limit to the phase (+/- 10 deg) at a specific location, and then cancel the limit with "w_p_limit 0 0". If "w_p_limit 0 0" has no effect, then the limit of +/-10deg will be there for the rest of the beam line, which is not what I want.
drift 10 10
w_p_limit 0 10
drift 10 10
w_p_limit 0 0
drift 10 10
Re: w_p_limit
I understand, so why not just put, "w_p_limit 0 100000" ?
bradpaul559 - Novice
Re: w_p_limit
Bonjour,
Ça ressemble à un problème de réinitialisation de la limite. Il est possible que la première commande w_p_limit 0 10 reste active et ne soit pas correctement écrasée par w_p_limit 0 0, un peu comme dans certains systèmes où une règle continue d’influencer le comportement (on retrouve ce type de logique dans le jeu Monopoly Roulette par exemple.
Vous pouvez vérifier si une réinitialisation explicite est nécessaire.
Cordialement.
Cordialement.
