terminal output gone
Posted: Fri 12 Jan 2024 15:42
Using version 2.23.2.6 command line interface, tracewin seems to clear stdout before tracking starts, including the previous terminal history (ie output from commands before the tracewin command). I do use the "hide_esc" argument in my command but that does not seem to help.
If I add the "hide" argument then this does not happen, but then I also see no output which is often quite useful.
Tested the linux version.
