Two sugesstiongs for Diag command and extract function
Posted: Sun 25 Feb 2024 12:29
There are some commands for beam size and divergence matching at different locations, including "DIAG_DSIZE2_FWHM", "DIAG_DSIZE2", "DIAG_DSIZE3", "DIAG_DPSIZE2". If there's a case that only X-plane matching is needed, then how to set the diag command? I suggest setting 2 matching accuracies for the special case:
ADJUST 1001 ...
QUAD ...
DRIFT ...
DIAG_DSIZE2 1001 0 0 0 1E51 ; Diag Number, △x, △y, dm△x, dm△y
DRIFT ...
By the way, on the interface of TraceWin, there's a tab named "Exe" for Extracting console executables. Do you mind including TraceWin_noGUI.exe in it? Such that we don't need to download it from the website manually after the software upgrade. Maybe other
Kinds,
shliu
ADJUST 1001 ...
QUAD ...
DRIFT ...
DRIFT ...
Kinds,
shliu
