about output file
Posted: Wed 13 Mar 2024 12:56
by fengxinyuan
dear Didier:
Why is the filename sometimes partran.out and sometimes partran1.out when I use tracewin in batch command?
fengxy
CSNS/ihep
Re: about output file  [SOLVED]
Posted: Wed 13 Mar 2024 13:54
Dear fengxy,
It's always partran1.out, normally the only way to find a pratran.out, is if the code crashes. If you have a configuration so that at the end of the run there is a partran.out file, let me know, because it's not normal.
Posted: Thu 14 Mar 2024 08:59
by fengxinyuan
oh, i just find the fault. i set a negative value to betaz by mistake, which make code crashed.
thank you!
Posted: Thu 14 Mar 2024 09:56
A negative value to betaz should not cause the code to crash, but rather an error message !!!
