Gas and Magnetic stripping losses  [SOLVED]
Can you briefly explain or direct me to the literature explaining how the gas and magnetic stripping loss rates are calculated in TraceWin?
With Regards
Abhishek Pathak
Re: Gas and Magnetic stripping losses  [SOLVED]
Dear Abhishek,
I've used reference below:
https://journals.aps.org/prab/pdf/10.11 ... .24.074201
For the gas command "GAS C, N, P," how do we define the atomic number for a molecule?
With Regards
Abhishek Pathak
Dear Abhishek,
For gas stripping N is useless,
Thank you for your clarification. To ensure my understanding is correct, I should use the cross section and the pressure to estimate the gas stripping losses, correct?
Additionally, I have another question: If I need to simulate a mixture of two gases, should I input two Gas commands consecutively, each with its respective cross-section and pressure?
Thank you once again.
Warm regards,
Abhishek Pathak
Dear Abhishek,
Yes it's correct.
No, a new GAS command cancels and replaces the preceding one. You need to define an effective cross-section representative of the combination of your 2 gases.
