Gas and Magnetic stripping losses
Posted: Mon 1 Apr 2024 15:36
by Abhishek
Can you briefly explain or direct me to the literature explaining how the gas and magnetic stripping loss rates are calculated in TraceWin?
Thank you
With Regards
Abhishek Pathak
Re: Gas and Magnetic stripping losses [SOLVED]
Posted: Tue 2 Apr 2024 17:57
Dear Abhishek,
I've used reference below:
https://journals.aps.org/prab/pdf/10.11 ... .24.074201
Posted: Wed 24 Apr 2024 18:59
by Abhishek
For the gas command "GAS C, N, P," how do we define the atomic number for a molecule?
Thank you
With Regards
Abhishek Pathak
Posted: Thu 25 Apr 2024 13:33
Dear Abhishek,
For gas stripping N is useless,
Posted: Fri 26 Apr 2024 16:08
by Abhishek
Thank you for your clarification. To ensure my understanding is correct, I should use the cross section and the pressure to estimate the gas stripping losses, correct?
Additionally, I have another question: If I need to simulate a mixture of two gases, should I input two Gas commands consecutively, each with its respective cross-section and pressure?
Thank you once again.
Warm regards,
Abhishek Pathak
Posted: Fri 26 Apr 2024 16:45
Dear Abhishek,
Yes it's correct.
No, a new GAS command cancels and replaces the preceding one. You need to define an effective cross-section representative of the combination of your 2 gases.
