Page 1 of 2
Error study crashes
Posted: Wed 17 Apr 2024 15:09
by Emmanuel
I have some troubles while using. Tracewin crashes with the following (the are many more lines of "QIODevice::read: device not open" message):
(process:4181943): GLib-ERROR **: 14:18:19.044: Creating pipes for GWakeup: Trop de fichiers ouverts
[1]+ Trappe pour point d'arrĂȘt et de trace (core dumped)$HOME/TraceWin/TraceWin
You can download an example here :
https://mycore.core-cloud.net/index.php ... TNuZJixE8B
My computer runs Fedora, and I use several servers under Fedora and AlmaLinux.
Emmanuel
Re: Error study crashes
Posted: Fri 19 Apr 2024 13:14
Dear Emmanuel,
Don't worry about message "QIODevice::read: device not open", your problem comes from somewhere else and I can't understand it at the moment.
Could you increase the limit of files that can be opened at the same time under linx using the command "ulimit -n 16384" and see if the error persists.
Posted: Fri 19 Apr 2024 16:17
by Emmanuel
I had the message "QIODevice::read: device not open" in the past but here, it was scarier... The number of cores might be the source of the multiple messages.
I tried the command ulimit -n 16384 but got the same error. I did some search about ulimit command, and then tried to increase the limit with ulimit -n 63536, as I checked the limits as described here
https://community.rsa.com/s/article/Wha ... -Lifecycle. But it didn't work.
So, I'm still stuck with this issue. You might be right pointing at a linux setting, so I'm going to search on this aspect on my side.
Best regards.
Emmanuel
Posted: Fri 19 Apr 2024 16:44
Dear Emmanuel,
You have around ten servers for a total of around 600 cores. For my part, I can test 100 to 200 cores, but on a single server. It would be interesting to know whether the problem comes from the number of cores or the number of servers.
Posted: Mon 22 Apr 2024 07:12
by Emmanuel
I tried this (reducing the number of cores), and also crashed. I'm going to try my project on a windows server.
Best regards.
Emmanuel
Posted: Thu 25 Apr 2024 13:39
Dear Emmauel,
For your information, I've fixed the problem with the "QIODevice::read: device not open" message. It won't change anything, but it will avoid poluting the display with the unusable warning.
Posted: Thu 25 Apr 2024 14:02
by Emmanuel
Thank you for the upgrade.
FYI the error study also crashed on the windows server. At the same time I launched the error study on one linux server, and... It's still running.
Emmanuel
Posted: Thu 25 Apr 2024 14:04
Dear Emmanuel,
Could you send me your ini file for the wndows server?
Posted: Thu 25 Apr 2024 15:11
by Emmanuel
Posted: Thu 25 Apr 2024 15:18
2 local machines only, that doesn't seem to me to be the ini file used on your windows server.
- remote_pc.png (49.91 KiB) Viewed 14980 times
