Edge of dipole application in envelope mode
Posted: Fri 5 Feb 2021 06:09
by shliu
According to my understanding, the edge of a dipole in envelop mode could be regarded as a kicker. My .dat file is as following:
EDGE 0 800 110 0 0 50 0
BEND 45 800 0 50 0
EDGE 45 800 110 0 0 50 0
The transfer matrix of the third element (the edge of the dipole) is
which means that it's defocusing in H plane and focusing in V plane. The question is, when I check the x' and y' envelop, there's only kick application in x', but without y':
I tried the dipole field map and found the kick effect is obvious in both planes:
kinds,
shliu
Re: Edge of dipole application in envelope mode
Posted: Fri 5 Feb 2021 11:41
Dear shliu,
On my side I see kick in both planes, but I didn't have your project configuration. Please send me your project files (*.ini, *dat), otherwise complicated for me to check your case.
Posted: Sun 7 Feb 2021 02:19
by shliu
Attached the .ini file.
There's an error message when I tried to attach the .dat file, so I put the content here:
BEND 45 800 0 50 0
end
Posted: Mon 8 Feb 2021 10:16
Dear shliu,
I fixed the problem in forum about the 'dat' file.
So, using your project, I find for 45° edge, the following behavoir and I found small vertical kick. And if I incease angle to 60° vertical kick become obvious.
Posted: Mon 8 Feb 2021 11:06
by shliu
I got it. Thank you!
