Input line parameters
Posted: Fri 10 May 2024 16:11
by comunian
what about adding as input variable parameters on the command line, for the no gui tracewin version, the following aspects:
1) Partran space charge options.
2) Input distribution type.
3) Partran energy and phase limits.
My Best Regards,
Michele comunian
Re: Input line parameters
Posted: Mon 13 May 2024 14:52
Is this just a suggestion for improvement (and thank for that) or a real need ?
Posted: Tue 14 May 2024 09:00
by comunian
as you can image, we are using TraceWin in a lot of various scenarios.
When we use it from the command line, i.e. without gui, some times we are not able to reproduce the results of the gui version, because some parameters are not the same in the used .ini file.
In my opinion, you can keep this as a possible improvement, but as a low priority.
Posted: Tue 14 May 2024 15:51
If that seems useful to you, then... it's done.
Posted: Tue 14 May 2024 15:58
by comunian
thank you!!!
B.R.
