Use of diagnostics on the second beam
Posted: Tue 9 Jul 2024 13:58
by comunian
is there any way to adjust the diagnostics differently between the first and second beam?
I mean a way to have different settings or avoid the action of the adjust on the second beam?
Re: Use of diagnostics on the second beam
Posted: Tue 9 Jul 2024 16:53
Dear Michele,
In real life, this would mean, for example, that a quadrupole would change value depending on the species that crossed it.
I don't really see the point of this, but could you explain why this requierement ?
Now clearly, there's no way of doing that.
Posted: Wed 10 Jul 2024 08:52
by comunian
yes, if you fully implement the feature, you get practically a second TraceWin project, not a run of a second beam.
We are designing a mebt coming from an RFQ, so we use the first beam with the rfq output without the not accelerated particles,
and the second beam with the not accelerated particles. So the mebt is set by the primary beam and we get the information on losses from the second beam.
The point is that sometimes we want to change where the not accelerated particles are lost by adjusting the second beam.
As a suborder request may we set the B value of the dipoles field, independently from the Brho ?
Posted: Wed 10 Jul 2024 09:42
Dear Michele,
Below is a proposal for modifying the B field independently of the Brho
CHANGE_BEAM 1 10e6
EDGE 12.5 500 100 0.45 2.8 150 0
BEND 25 500 0 150 0
CHANGE_BEAM 1 -10e6
