Remote cores not fully used in error studies
Posted: Fri 19 Jul 2024 14:55
When using Tracewin for error studies, tracelx64 processes run on the number of cores set in TraceWin, but with a very low efficiency. Each tracelx64 process uses a core at less than 15% (often between 5 and 12 %).
Is there any setting to make in TraWin to prevent such a behaviour ?
Than you for any help.
Emmanuel
Emmanuel
