Segmentation violation error when importing second beam
Posted: Wed 24 Feb 2021 08:50
by FrancescoS
I have a segmentation violation error when importing beam parameters from a dst file in the second beam.
The same file works ok if I use it as a first beam.
I mean, on main beam I have no problems, but with the second beam I have the error.
Any help?
Thank you in advance
F.
Re: Segmentation violation error when importing second beam
Posted: Wed 24 Feb 2021 10:07
Dear Francesco,
I have tried a similar configuration without any problems. I therefore need to attach here the set of files of your project including the dst files.
Posted: Wed 24 Feb 2021 10:11
by FrancescoS
I just realized I have an outdate version, I will try with the new version and I'll be back to you
Thanks
F.
Posted: Wed 24 Feb 2021 13:44
by FrancescoS
well, it happens also with the newest version.
The strange issue is that these two file works ok in the main beam, but none of them works in the second beam...
I will try to rewrite the project or redo the dst files.
Can I eventually send you everything privately?
Posted: Wed 24 Feb 2021 14:05
yes, of course
Posted: Thu 25 Feb 2021 16:28
Dear Francesco,
The bug you found is corrected in the last release.
Posted: Fri 26 Feb 2021 07:44
by FrancescoS
Thanks a lot.
do you mean a new version of the code is already available for Download?
Posted: Fri 26 Feb 2021 08:50
Dear Francesco,
Yes of course, please upgrade your code and check.
Posted: Fri 26 Feb 2021 09:07
by FrancescoS
Thanks, I will do it later on today!
Cheers
F.
Posted: Fri 26 Feb 2021 11:55
by FrancescoS
it works perfectly now!
thanks a lot
