Cavity error calculations with aperture map
Posted: Wed 28 Aug 2024 13:03
by jonathan dumas
it seems that cavity error calculations with aperture maps lead to a TraceWin critical error.
Is it possible to mask FIELD_MAP 0 for cavity errors?
I put an example here:
field_map_path TraceWin\doc\examples
ERROR_CAV_NCPL_STAT 1000 10 1 1 1 1 1 0 1
DRIFT 10 40 0 0 0
DRIFT 10 40 0 0 0
SUPERPOSE_MAP 0
ouverture: FIELD_MAP 0 1280 0 18 0 0 0 1 solenoid1
SUPERPOSE_MAP 0
FIELD_MAP 0010 1280 0 71 155 0 0 0 solenoid1
DRIFT 10 40 0 0 0
DRIFT 10 40 0 0 0
end
Re: Cavity error calculations with aperture map
Posted: Wed 28 Aug 2024 15:35
Dear Jonathan,
Are you an exmaple to provide me?
Posted: Wed 28 Aug 2024 15:42
by jonathan dumas
Here's the example, see attached,
Jonathan
Posted: Wed 28 Aug 2024 16:52
Dear Jonathan,
Bug fixed,
Posted: Thu 5 Sep 2024 14:59
by jonathan dumas
I reopen the topic.
Is it possible to mask FIELD_MAP 0 for cavity errors completely?
I think this is why I observe bigger losses than with hardedge. I basically double the errors, see attached the error_data file when I run error calculations.
I don't think there is any situation in which someone would need to apply errors to an aperture field map.
Jonathan
Posted: Thu 5 Sep 2024 15:57
Dear Jonathan,
I'll check that, but as usual I need your project files.
Posted: Thu 5 Sep 2024 16:25
by jonathan dumas
ok it will be easier to reuse the one with the fieldmaps that you provided in the examples of TraceWin.
If you run the project attached, the error_data file shows a transverse shift of 1 mm applied to the aperture map.
Although if you put a shift in X of 200 mm, I see that particles are not lost so maybe this error is not effective ?
Posted: Thu 5 Sep 2024 16:57
Dear Jonathan,
Ok It's fixed, but as it has no impact on simulations or even visualisations, it will not be effective until a later update.
