Beam acceptance
Posted: Thu 14 Nov 2024 16:45
I'm having trouble calculating the beam acceptance of a beam along a cavity. From an initial distribution, I run the simulation and I get the output phase space, with which I calculate the acceptance with PlotWin from the method explained in the Manual (Acceptance calculation using TraceWin and PlotWin).
However, when I use this distribution as input, the beam is not transmitted well through the same cavity, when it should be transmitted without losses. I think there is a problem with the longitudinal definition of the beam.
I have also tried to verify the simulations with the backtrack feature, but I am not able to perform the backtrack simulation.
