double free or corruption
Posted: Fri 6 Dec 2024 12:16
by Lennert.dk
I'm having issues when running error studies on a linux computing cluster.
These are the steps I follow:
1) I connect to a computing node that has reserved 50 cores for my job.
2) In the list of computers in the 'Errors'-tab I just have the Local (0.0.0.0) computer selected with 50 cores.
3) I start the error study.
Now from time to time the study finishes without any issues, but most of the time I get the following segmentation fault:
*** Error in `TraceWin_noX11': double free or corruption (out): 0x00007f029c0049e0 ***
Critical system error: Abnormal termination (abort).
It seems like a memory-related issue, but how to circumvent this?
When I run the same routine with the GUI ('TraceWin'), I don't have this problem.
Kind regards,
Lennert
Re: double free or corruption
Posted: Fri 6 Dec 2024 14:22
Dear Lennert,
I've carried out a few similar tests on my own without observing this type of error. So it's probably due to your configuration that I don't know about, or some options in your projects. Could you send it to me if it's not too complicated ?
But I've noticed display problems with the Linux version, which I've corrected and put on the site.
Posted: Fri 6 Dec 2024 15:30
by Lennert.dk
The files are added in the attachment (field maps exluded). Cheers, Lennert
Posted: Fri 6 Dec 2024 16:29
Dear Lennert,
In similar configurations I've never had any problems, so maybe it's down to your project, but I can't test it without the field map files!
Posted: Mon 9 Dec 2024 13:26
by Lennert.dk
You can find the field maps in the attachment. Thanks in advance! Kr, Lennert
Posted: Tue 10 Dec 2024 18:01
Dear Lennert,
I've fixed the bug that caused the noX11 version to crash, but the GUI version is normally affected too, although it seems more stable.
Posted: Tue 10 Dec 2024 18:30
by Lennert.dk
Cool, thanks! Kr, Lennert
