Max number of adjust command on TraceWin
Posted: Fri 21 Feb 2025 08:22
by comunian
may you increase the number of maximum ADJUST command, now the limit is 9, may you increase that to 18 ?
Re: Max number of adjust command on TraceWin
Posted: Fri 21 Feb 2025 16:27
It's done,
Posted: Mon 24 Feb 2025 12:13
by comunian
thank you for the work done.
I've a question: is there a way to use the results of envelope adjust matching for the partran values matching ?
I've attach an example: What I would like is to use the results of the quads: 36.49 and -9.26 as first values for the partran matching,
instead the code use the values of 10 and -10 as values for the quads when is doing the first partran matching.
Posted: Mon 24 Feb 2025 13:13
In your example, the number of steps for partran matching is set to 0, so nothing is done except take the values calculated in envelope.
If I set the number of steps to non-null, then obviously the values calculated in envelope are used as the starting point for tracking matching. I don't understand your comment.
Posted: Mon 24 Feb 2025 13:22
by comunian
sorry!
You have reason: there was not matching on patrtran.
