Chopper optimization
Posted: Fri 7 Mar 2025 10:28
by pedro
I would like to optimize a chopper, adjusting its voltage, length and/or aperture. The problem is that the ADJUST and DIAGNOSTIC commands do not work on the chopper element, and therefore their variation does not occur during the optimization. Would it be possible to implement this in the code?
Re: Chopper optimization
Posted: Tue 11 Mar 2025 13:45
Dear Pedro,
CHOPPER is not an element but a command, so there's no way to adjust these parameters, except for the length of the elements to which this command applies, i.e. drifts if you've placed this command in front of drifts. The only solution here is to create your own elements (see the manual chapter: "Develop its own element or diagnostics" )
