"Critical system error (GUI) : Segmentation violation" under linux version
Posted: Wed 16 Apr 2025 10:58
by Emmanuel
Since one of the new versions in February this year, I'm experiencing the error "Critical system error (GUI) : Segmentation violation" more often, up to several times a day.
There's no other indication that could help guess what's the source this system error.
I run TraceWin under Fedora 41.
Thank you in advance if you can provide any help.
Emmanuel
Re: "Critical system error (GUI) : Segmentation violation" under linux version
Posted: Wed 16 Apr 2025 13:29
Dear Emmanuel,
I doubt that the problem is the OS version and obviously on my side I don't observe such problems otherwise I would have corrected them.
So it's probably your project (could you send it to me).
Otherwise, I sent you a private message with a link to a version (debug and slower of course) but which generates a "tracewin_debug.log" file, please send it to me after a crash.
Posted: Tue 5 Aug 2025 11:00
by Emmanuel
I noticed during the last 2 weeks, that I get this error message systematically when I use synchronized "Normalized particle density" charts with the option "Add beam size in "density" chart" activated.
In case it's of some help to find where it fails.
Emmanuel
Posted: Mon 25 Aug 2025 10:47
Dear Emmanuel,
Bug about denity plots synchonization has been fixed.
Posted: Thu 4 Sep 2025 12:12
by Emmanuel
Following the update, other error messages appeared leading to "Critical system error (GUI) : Segmentation violation", then TraceWin crashes without the possibility to save before it stops. It happened at least 3 times.
I copied the last messages in the text file attached.
Regards.
Emmanuel
Posted: Thu 4 Sep 2025 14:18
Dear Emmanuel,
It looks like it's when you ask for the code's online help, is that right?
Posted: Thu 4 Sep 2025 15:26
by Emmanuel
It happened at least once when after several help requests.
The last time, it happened after I opened PlotWin.
Emmanuel
Posted: Thu 4 Sep 2025 16:59
Dear Emmanuel,
I found an error directly related to your error message. It shouldn't have caused fault segmentation, but who knows. New version available for download.
