Synch on PlotWin
Posted: Sun 18 May 2025 02:58
by wtam
The synch. button in the plots generated by PlotWin seems to be broken.
Re: Synch on PlotWin
Posted: Sun 18 May 2025 17:19
by wtam
It could sometimes be fixed by restarting PlotWin. Sometimes I have to restart TraceWin to fix it.
I am fine with that.
Posted: Mon 19 May 2025 09:52
What exactly do you mean by "broken" ?
What does this have to do with a TraceWin reboot ?
Posted: Mon 19 May 2025 17:43
by wtam
"Broken" has a few symptoms:
(1) Synch does not update or refresh
(2) When Synch does not work, restarting PlotWin the plots could be weird. For example, some elements do not show up.
(3) Sometimes the plots from PlotWin would show "Trial Version". Restarting PlotWin can fix it.
Restarting TraceWin, and then restarting PlotWin, could fix the above.
Posted: Tue 20 May 2025 15:51
I've made a few corrections in the hope that it will behave better.
Posted: Thu 22 May 2025 17:43
by wtam
Thank you for making the corrections.
Now it would try to synch during a partran optimization, which stalls PlotWin and returns error.
Posted: Fri 23 May 2025 09:48
Sorry, I didn't understand your answer, it doesn't work at all?
Posted: Mon 9 Jun 2025 13:43
by wtam
I am sorry for the confusion.
The fix works. But it created another issue. The new issue is that PlotWin now synchronizes at each step during a Partran simulation. As a result, PlotWin could become frozen.
Posted: Tue 10 Jun 2025 10:14
I think we're having trouble understanding each other on this subject
Basically, PlotWin's synchronization works in the same way as TraceWin's, i.e. every time the monitored file changes, i.e. every time an optimization step is taken. That's the basic principle. So normally this shouldn't block PlotWin, but it seems to be the case for you ?
