Lattice command
Posted: Fri 11 Jul 2025 10:17
by mahendra2
Can you explain what Lattice command do, say if i define a FODO with lattice command and i only define the fodo elements but not keep with in lattice command . Then what will be the difference?
Re: Lattice command
Posted: Fri 11 Jul 2025 10:32
Dear Sir, Hello
I don't understand what you're asking. Please be more specific. Some examples ?
Re: Lattice command
Posted: Fri 11 Jul 2025 10:52
by mahendra2
say i have one structure file like Lattice 2 1 ,drift, quad, drift, quad, drift, lattice_end and another i dont use Lattice command so structure file like drift, quad, drift, quad, drift and transport beam in both how the result is different or what is difference between this two structure file.
can you explain when to use lattice command
Re: Lattice command
Posted: Tue 15 Jul 2025 10:23
Dear Sir,
DIRFT QUAD DRIFT QUAD, normally it's LATTICE 4 1, because your period is made up of 4 elements.
Anyway, this lattice command doesn “t change anything to the simualion in these elements, it just allows the code to know your period in order to calculate the phase advances according to the period you're defined.
Re: Lattice command
Posted: Tue 15 Jul 2025 11:10
by mahendra2
is lattice 2 2 can be used instead of lattice 4 1
Re: Lattice command
Posted: Tue 15 Jul 2025 11:12
In your case, I don't think so.
Re: Lattice command
Posted: Wed 16 Jul 2025 09:26
by mahendra2
i want to get the best value of quad strength which match the beam with given twiss parameter, how to do? my structure file is like:
DRIFT 200 100
MATCH_FAM_GRAD 1 1
QUAD 100 20 100
DRIFT 400 100
MATCH_FAM_GRAD 1 2
QUAD 100 -20 100
DRIFT 200 100
set_twiss 1 -1.246384 1.002772 1.246384 1.002772 0 0 (desired twiss at input and output)
END
is it correct ? i am not getting change in quad strength from 20
Re: Lattice command
Posted: Wed 16 Jul 2025 09:49
Dear Sir,
Follow the right syntax :
DRIFT 200 100
MATCH_FAM_GRAD 1 1
QUAD 100 20 100
DRIFT 400 100
MATCH_FAM_GRAD 1 2
QUAD 100 -20 100
DRIFT 200 100
set_twiss 1 -1.246384 1.002772 1.246384 1.002772 0 0 0 0 0 0 1 1
DRIFT 0 100
END
Generally speaking, I can't check whether what you're doing is correct without your project configuration files. On the other hand, I suggest you don't use this method (MATCH8FAM_XXX...) but rather the ADJUST commands associated with diagnostic elements such as DIAG_XXX. It''s easier to andestand and use and powerful.
