PLOT_DST limit error
Posted: Tue 25 May 2021 11:28
by emo
Lately I get this error message sometimes during PARTRAN optimizations.
PLOT_DST number limited to 500
From->[PARTRAN] Library
From->[PROCESS_ENVELOPE] : Run PARTRAN
From->[PROCESS_ENVELOPE] : Run multiparticle program
It happens only sometimes and I cannot find the reason.
Once it has happened, I cannot continue with the optimization until I restart TraceWin.
It happened at step #250 although the limit of iterations was set to 500 for multiparticle in the 'Matching' tab.
Thank you in advance for your assistance.
Re: PLOT_DST limit error
Posted: Tue 25 May 2021 12:23
Dear Emo,
I think I've found the problem, but I'm not sure because I don't know exactly what you are doing. Before I put a new corrected version online, I would like to see your project if it is possible for you. Could you post your project files, *.dat and *.ini
Posted: Tue 25 May 2021 17:43
by emo
Thank you for the fast reply.
Apparently two of my collaborators experienced similar problems.
Here are the .ini and .dat files.
I am afraid I made some changes in the TraceWin settings after the error showed.
I hope it will not make it difficult to find the source.
Thank you in advance.
Emil
MEBT3 section_v01b.ini
(30.88 KiB) Downloaded 667 times
mebt3 section_v01b.dat
(14.93 KiB) Downloaded 757 times
Posted: Wed 26 May 2021 10:11
Dear Emo,
Thank for your project files.
Ok, problem is now fixed in the new TraceWin version available. So please upgrade your code.
