Multiparticle Envelopes Plots
Posted: Wed 25 Mar 2026 14:18
by comunian
I've done a linac design by using GenLinWin. What I've noted is that is reported by the envelopes plots a not correct sequence of elements, i.e. in the attached envelope.png the yellow box should be reported only two times, because I'm using two cavities. Instead the FM1 and FM2 maps are reported correctly.
May you handle that?
I've attached also the whole tracewin project.
Re: Multiparticle Envelopes Plots
Posted: Wed 8 Apr 2026 13:00
Dear Michele,
I was sure I’d replied to you, but now I’m not so sure.
Anyway, never mind and sorry for the delay.
The yellow box indicates the number of gaps in your cavity. Here there are 2, so, 4, because you have two cavities side by side
