Question about SPACE_CHARGE_COMP and FIELD_MAP (Ki parameter) in TraceWin
Posted: Wed 29 Apr 2026 09:42
by ZY Song
I have a few questions regarding the use of space charge compensation in TraceWin that I would like to clarify.
For a proton beam, I understand that the space charge compensation can often be approximated as about 90%. Therefore, I set in my data file:
SPACE_CHARGE_COMP 0.9
Based on this, I would like to confirm the following points:
1. Scope of SPACE_CHARGE_COMP
Does the command `SPACE_CHARGE_COMP`: apply only to the immediately following element, or act as a persistent state that applies to all subsequent elements until another `SPACE_CHARGE_COMP` command is defined?
2. Interaction with FIELD_MAP when Ki = 0**
If I want to apply a uniform space charge compensation of 0.9 along the entire beamline, for example:
DRIFT 109 130 0 0 0
FIELD_MAP 007 880 0 100 0 1 0 20250902
DRIFT 109 130 0 0 0
END
I would like to confirm: When **Ki = 0** in the `FIELD_MAP` element (i.e., no `.scc` file is used), does the FIELD_MAP element still use the compensation defined by `SPACE_CHARGE_COMP 0.9`?
In other words:
When Ki = 0, is the space charge compensation inside FIELD_MAP controlled by the previously defined `SPACE_CHARGE_COMP`?
3. Behavior after FIELD_MAP using .scc
If a FIELD_MAP uses a `.scc` file (Ki > 0), what happens for the elements after it?
For example:
DRIFT ...
FIELD_MAP ... (Ki = 1, using .scc)
DRIFT ...
END
After the FIELD_MAP, does the following DRIFT element: automatically return to the previous `SPACE_CHARGE_COMP 0.9`, or do I need to explicitly redefine `SPACE_CHARGE_COMP 0.9` again?
Thank you very much for your help.
Re: Question about SPACE_CHARGE_COMP and FIELD_MAP (Ki parameter) in TraceWin  [SOLVED]
Posted: Wed 29 Apr 2026 13:52
1) It acts as a persistent state that applies to all subsequent elements until another `SPACE_CHARGE_COMP` command is defined.
2) Ki is only used if an .scc file is present. When the map is exited, the value normally reverts to that defined by SPACE_CHARGE_COMP. It's not certain, but it's not very difficult to check and see and yes, if it doesn’t work, simply repeat the command.
