Question about mutipole component at dipole
Posted: Tue 26 May 2026 09:52
by msh3069
Dear all
I want to study the effects of higher-order multipole components in a bending magnet by systematically varying them.
I noticed that the standard BEND element properties don't seem to support direct multipole inputs, and the error definitions don't quite cover what I need.
Is my only option to use a 2D/3D field map (FIELD_MAP / B_MAP) for the dipole? Or is there a way to overlay a MULTIPOLE element at the same location as the BEND, or perhaps use a different element type altogether?
Best regards
SeokHo Moon
Re: Question about mutipole component at dipole
Posted: Thu 28 May 2026 10:20
Dear SeokHo Moon,
I suggest you use the standard BEND dipole, then cut it in half and insert either a quadrupole (QUAD), using only its multipole components, or the MULTIPOLE element.
Posted: Thu 28 May 2026 10:32
by msh3069
Thanks for your suggestion, I will try it as you said.
