calculating periodic phase advance from TraceWin.output
Posted: Thu 23 Jul 2026 04:53
by Dreamer
I want to calculate periodic beam phase advance from TraceWin.output, but I couldn't calculate the correct result. I have put the relevant details in the attachment.
Li.
Re: calculating periodic phase advance from TraceWin.output
Posted: Thu 23 Jul 2026 10:19
Dear Li.
I understand your problem, but it’s too complicated to solve without your project files.
Could you please send them to me, including the field map file?
Posted: Fri 24 Jul 2026 11:35
by Dreamer
this is my project files.
test_pa.rar
(357.41 KiB) Downloaded 116 times
regards,
Li.
Posted: Fri 24 Jul 2026 15:43
Dear Li,
I fixed a bug about phase advance in tracewin.out file when FIELD_MAP element is used.
Upgrade your code.
Posted: Sat 25 Jul 2026 04:35
by Dreamer
Thank you very much. After testing, I found that the results are now correct.
regards,
Li.
Posted: Sun 1 Nov 2026 10:52
by gwhitlock68
Glad it's sorted, Dreamer... only thing I'd add is rerun any older FIELD_MAP projects you did before the upgrade, cos the old output files will still have the dodgy phase advance numbers in them. I learnt that one the hard way, spent a week comparing against an old file and wondering why nowt matched, bloody daft.
