RF cavity transient analysis with TraceWin
Posted: Tue 27 Jul 2021 10:05
by Bruce Yee
On the manual, the quality factor of the loaded cavity (QL) is given by:
1/QL=1/Q0 + 1/Qi + 1/Qt... (1)
How TraceWin estimated the incident coupling (Qi)?
Qt is given, and Q0 can be estimated from the input parameters. I would like it if you could explain to me a little more about Qi.
Re: RF cavity transient analysis with TraceWin
Posted: Wed 28 Jul 2021 15:48
Qi is calculated one time at begening as following:
Qolow=G/Rs*(1+A*Eaccnom);
Q0i=Qolow-(3./4.)*Qolow*Eaccnom/10e6;
Qi=Eaccnom*Lacc/(rsq*I_Beam*cos(Ph_Sync)+Eaccnom*Lacc/Q0i);
Posted: Thu 29 Jul 2021 07:11
by Bruce Yee
Thank you very much for the information.
I have to more questions:
1) About the equation "Q0i=Qolow-(3./4.)*Qolow*Eaccnom/10e6;", Could you tell me how this equation is obtained? or some references.
2) When you said that "Qi is calculated one time in the beginning"?
Do you mean that later it is estimated by other relation like Qi= omega*U/Pinc?
Thanks again for your time and help.
Posted: Mon 2 Aug 2021 16:04
For the moment I can't seriously answer your questions without asking the historical developer of this part of the code. Coming back only at the end of August, I will try to clarify these points at that time
Posted: Thu 5 Aug 2021 12:36
Finally, I was able to exchange with the expert on these questions here and I can better answer your questions.
1) This equation is only a linear estimation of the behaviour of Qo as a function of Eacc starting from a more or less usual curve. In any case Qo has little impact on QL
2) Qi is not re-evaluated in the transients, we consider this sufficient.
