Field maps for diple with edge angle and fringe-field correction in TraceWin
Posted: Mon 18 Oct 2021 03:21
by shliu
Dear Didier:
Edge element is treated as thin lens in TraceWin, and the transfer matrix is defined by 5 parameters: K1, K2, gap, curvature radius, edge angle.
I tried to export the field map of a dipole with edge angles but the field map doesn't exit in hard edge model:
EDGE 15 3500 120 0 0 70 1
BEND 30 3500 0 70 1
I noticed "MULTIPOLE" command with Order=1 but there's no edge angle or fringe-field correction.
Do you have any suggestions for exporting the 3D field maps of a dipole with edge angle and fringe-field correction? Or the expression B(s) similar to Enge function?
Re: Field maps for diple with edge angle and fringe-field correction in TraceWin
Posted: Tue 19 Oct 2021 08:45
Indeed the hard-edge model of the dipole has its limits, but if you have the 3D field map of the dipole, why not use it directly?
Posted: Wed 20 Oct 2021 04:44
by shliu
Dear Didier:
Thanks for the reply.
So there's no difference between "Edge" and "Quad" if the gradient of the quadrupole is proper, right? If so, it is still a hard-edge model for "edge" command, and K1, K2 doesn't describe the fringe field shape.
I'll use the 3D field map directly.
Posted: Wed 20 Oct 2021 16:56
by npichoff
The model of the edge is given in (p.117) :
https://cds.cern.ch/record/283218/files/SLAC-75.pdf
You are right, edges are modeled with a matrix of thin length model of quadrupoles.
Nevertheless, there is a small difference in the focusig/defocusing X/Y coefficients given by a corrective factor, which can be found in the publication given before, but which is not given in some other publications.
Our recommandation is to use the field map as much as possible in all your calculations.
If you want to use simple linear models (for example to speed up your calculations), the best is first to adjust the coefficients of the model by comparing particle transport in the model and in field map.
Best regards.
Nicolas.
Posted: Thu 21 Oct 2021 02:27
by shliu
Dear Nicolas,
Thank you for the confirmation.
