Quadrupole shifts beam phase?
Posted: Mon 8 Nov 2021 16:32
by hendrik.haehnel
we found some weird behaviour in TraceWIn. This arbitrary example only has a drift section, a triplet and two buncher gaps.
Somehow, the beam center phase is shifted in the Quadrupole. Is this just some numerical error for this edge case (not a realistic case)? Or is there some bug?
DRIFT 15 50
DRIFT 25 50
QUAD 8 100 18
DRIFT 5 18
QUAD 10 -100 18
DRIFT 5 18
QUAD 8 100 18
DRIFT 5 15
DRIFT 5 15
GAP 400 -90 15
DRIFT 28 15
GAP 400 -90 15
DRIFT 5 15
END
Image of the envelope (phase shifted in Quadrupole)
Project file attached below.
Hendrik
Re: Quadrupole shifts beam phase?
Posted: Tue 9 Nov 2021 16:43
Dear Hendry,
Considring your very low beam energy, the transverse dispersion becomes non-negligible. Try with a very small transverse emittance to see that the effect disappears.
Posted: Tue 9 Nov 2021 16:47
by hendrik.haehnel
Tank you, you are absolutely correct. I should have thought of that.
Hendrik
