About error ERROR_STAT_FILE
Posted: Mon 13 Dec 2021 04:48
by shliu
Dear Sir,
I wonder How to use the command of 'error_stat_file ERROR_STAT_FILE static_error_file.txt'? I put this command in the begain of the lattice as follow,but the error message 'error_stat_file FILE missiong'. Could you give me an example of application? Thank you so much!
Shuhui Liu
lattice:
FREQ 650
ERROR_STAT_FILE D:/Error_Datas_stat.txt
FREQ 650
;CELL 1
DRIFT 50 40 0 0 0
;SUPERPOSE_MAP 0 0 0 0 0 0
FIELD_MAP 70 500 0 40 -0.438661 0 0 0 Q180b 0
adjust 1 5 1 -1 1 -0.2
FIELD_MAP 70 500 0 40 0.0 0 0 0 Q180_Cxb 0
adjust 1 5 2 -1 1 0.2
FIELD_MAP 70 500 0 40 0.0 0 0 0 Q180_Cyb 0 ;SUPERPOSE_MAP 410 0 0 0 0 0
;shift 1 1
FIELD_MAP 70 500 0 25 0.653174 0 0 0 Q240b 0
;adjust 1 5 3 -1 1 -0.1
FIELD_MAP 70 500 0 40 -0.0 0 0 0 Q240_Cxb 0
;adjust 1 5 4 -1 1 0.1
FIELD_MAP 70 500 0 40 0.0 0 0 0 Q240_Cyb 0
end
Re: About error ERROR_STAT_FILE
Posted: Mon 13 Dec 2021 10:02
I checked an simalar example without problem.
Does your "Error_Datas_stat.txt" file really exist?
Anyway, please find here my example.
example.zip
(10.1 KiB) Downloaded 323 times
