Gas scattering
Posted: Tue 1 Dec 2020 14:04
I would like to ask about the gas scattering implementation in Tracewin.
In the "GAS" command, only pressure and atomic number are demanded, but no cross section is required for scattering calculations (the cross section in the GAS command will be used for gas stripping, I assume). I would like to know if this feature has been validated (benchmarking with some other codes) and if we can rely on such results. I would appreciate more information about the physic model describing such interactions.
