Key Error
Posted: Tue 16 Aug 2022 11:26
by jonathan dumas
there is a popup window that informs me that there is a "Key error" and that the version is too old, see attached.
I updated TraceWin and the key today.
Is it possible to disable this popup window? It blocks batch calculations until I press "OK".
Jonathan
Re: Key Error
Posted: Wed 17 Aug 2022 09:59
Dear Janathan,
I don't understand!
The TraceWin update didn't fix the problem, the message still appears ?
Re: Key Error
Posted: Wed 17 Aug 2022 10:37
by jonathan dumas
Yes, it still appears after the update!
It's very random, it might be after a few hundreds of TraceWin uses
I can add in my script a function (hereafter in case someone has the same problem, for Windows/Python) to press all the time on the ok button of this window in case it appears but it's not ideal:
import win32gui, win32con, win32api
from datetime import datetime
cmptErr=0
def closeKeyError(win_title):
    handle = win32gui.FindWindow(0, win_title)
    global cmptErr
    if win32gui.IsWindow(handle):
        win32api.SendMessage(handle, win32con.WM_CLOSE, 0, 0)
        cmptErr+=1
    else:
        win32api.Sleep(60000)
    print("Time:",datetime.now(),"Still Running. Key error count:",cmptErr)
while True:
    closeKeyError("Key error")
Re: Key Error
Posted: Wed 17 Aug 2022 13:24
Hi Jonathan,
I've looked at the code, but I can't see any reason for this message to appear and if it's random it's even more incomprehensible.
I have added information in the error message dialog and in the "tracewin_key.log" file to understand. So next time if you are able to keep the message or the log file, send it to me so I can understand.
Of course you still have to upgrade the code to get these extra details.
Re: Key Error
Posted: Thu 10 Nov 2022 16:20
by Abhishek
I am using TraceWin 2.18.6.0, and I am still getting this message (as attached). May you please look into it? This occur when I run TraceWin in Batch mode for a very large number of runs.
Thank you
With Regards
Abhishek Pathak
Re: Key Error
Posted: Thu 10 Nov 2022 17:12
Dear Abhishek,
Is it systematic or only for certain runs?
Could you tell me exactly what your bacth command is?
Do you have the same problem if you use "TraceWin_noGUI.exe" which is exactly the same code without GUI?
Re: Key Error
Posted: Thu 10 Nov 2022 17:23
by Abhishek
I think is not systematic; sometimes, it appears consecutively sometimes it does not. My batch command is,
TraceWin config.ini path_cal=',num2str(k),'\',num2str(i),'\ Ele[',num2str(en(k)),'][2]=',num2str(F(I))
where I run a for loop over I and k and assign respective calculation directories. Here I also change the gradient of the quadrupole command. Ele[',num2str(en(k)) represents the quadrupole element number, and num2str(F(I)) stores the gradient range that I want to use.
So far, I have not tried the "TraceWin_noGUI.exe" option. I will try and see what happens.
Thank you
With Regars
Abhishek pathak
Re: Key Error
Posted: Fri 11 Nov 2022 12:21
Dear Abhishek,
I understood the problem thanks to your various information. It is now fixed in the latest version available on our website.
