Hoffmann Chart
Posted: Sat 10 Sep 2022 18:04
by sarvesh
I request you explanation of this Hoffmann Chart of the RFQ model. Can we say also that it is plot of σT/σ0T versus σz/σT? Can you please corelate the X and Y axis in this way. What is conclusion of yellow dots which is data from multiparticle simulations. I enabled all 4,3,2 order while plotting this Hoffmann chart. What should be relevant range on X axis?
Re: Hoffmann Chart  [SOLVED]
Posted: Fri 16 Sep 2022 13:22
by npichoff
Dear Sarvesh,
You are right : w is for x or y, then w=T=transverse (generaly, in linac, the focusing is the same in both transverse directions).
Can you please correlate the X and Y axis in this way.
This is a specific development. Nevertheless, you can plot them by yourself from plots of sigmaX0, sigmaX, sigmaY0, sigmaY for each period.
Each dot corresponds to one lattice of your linac.
Very often, resonances cannot be avoided during your acceleration. In this case, the best is not to stay a long time at this resonance (emittance transfer takes some time). The multiparticle simulations will inform you if there is emittance transfer between plan.
Regards.
Nicolas.
Re: Hoffmann Chart
Posted: Sat 17 Sep 2022 13:04
by sarvesh
I forget to mention that it is plot for RFQ only. Thanks to pointed reply, Can we also say that there is fast crossing of four lattice periods with tune depression more than 0.7 and therefore no significant effect on beam dynamics. I am counting yellow dots for Kz/Kxy = 1. What is the reason for it? Also what is the significance of dotted line?
Re: Hoffmann Chart
Posted: Sun 18 Sep 2022 11:38
by npichoff
For a better understanding of Hoffman chart, may I suggest that you read Ingo's (Hoffmann) paper ?
OK. this explain the reason why you have a lot of dots with kz<<kw (during the bunching process).
I don't really understand your question, can you please rephrase it ?
If you are talking about the vertical one, I assume that is corresponds to kz = kw.
Re: Hoffmann Chart
Posted: Mon 28 Nov 2022 09:57
by jonathan dumas
