Bending tuning using field map
Posted: Tue 20 Sep 2022 11:57
by conoa
Hello Didier,
I have some doubts about the proper way to tune a bending magnet when we use a field map to obtain the nominal line deviation. Once the magnet is electromagnetically designed, the field map could lead to a slightly different beam deviation and some matching of the kb parameter could be needed.
The only way I found was to obtain the approximated angle by using the X deviation with the envelope plot, but obviously it is an approximated calculation.
Is there any other way to ensure that the field map of the dipole is ok and we don't have to change the kb (that is, the dipole current) to follow the designed deviated path?
Conchi
Re: Bending tuning using field map
Posted: Thu 22 Sep 2022 11:20
Hi Conchi,
No, I can't see any other way, and indeed you have to grope around, but normally you converge relatively easily.
Posted: Fri 23 Sep 2022 14:00
by conoa
Thank you Didier!
