Steering inside field maps
Posted: Fri 23 Sep 2022 14:05
by conoa
Hello Didier,
I have a question regarding the use of steerers inside field maps. Generally, steerers, used as correctors, are not fully characterized from magnetically point of view, so they are not inserted as field maps, but with the hard edge model. However, if we use long field maps for quadrupoles and the steerers are located inside such field maps, how can we simulate them? I understand the shift_in_field map can be only applied to diagnostic but not to steerers.
Thank you
Conchi
Re: Steering inside field maps
Posted: Sun 25 Sep 2022 16:19
Dear Conchi,
You can use the STERRER command which will position a thin steerer in the middle of the field map
