Link variables in ADJUST
Posted: Wed 1 Mar 2023 05:35
by wtam
I would like to make a request. Could you add proportionality to the ADJUST command? For example:
adjust 1 1 1
drift 100 10
adjust 1 1 n
drift 100 10
The link could be n=1 or n=-1. Could you make be any number? e.g. n=0.5
Thanks and best regards,
Re: Link variables in ADJUST
Posted: Wed 1 Mar 2023 14:48
Your proposal syntax is not possible, but I added to ADJUST command, a new parameter 'kn' (see manual) allowing to do what you want.
Posted: Wed 1 Mar 2023 22:12
by wtam
Thank you. Could you have potentially introduced a bug in the new version? It crashes on some of my models that run fine on the previous version.
Posted: Wed 1 Mar 2023 22:45
I'm sorry for that, unfortunately, I've tried different projects and options but I don't see any problems on my side. Can you tell me more or show me more.
Re: Link variables in ADJUST  [SOLVED]
Posted: Thu 2 Mar 2023 05:48
by wtam
Thank you for testing on your side.
I cannot show more. When I hit run, it flashes and disappears. It had happened several times in the past after a TraceWin upgrade. I suspect that it might be due to the cloud storage and firewall settings on my company computer. Since a few months ago, the "Upgrade software" button wouldn't start the download. I will investigate on my side.
Thanks and Best regards,
