[solved] DTL_CEL/partran/cli segfault
Posted: Tue 14 Mar 2023 10:15
I have a DTL lattice I tried to run using the CLI (noX11) on Linux, but I get a segfault. I manage to make a minimal example attached.
It looks like if I use QUAD instead of DTL_CEL then it does not fail. It also seem to only fail when partran is turned on. Finally it works fine if I run in GUI, and it works with older CLI versions (not sure when this issue started).
The output I get is:
Multiparticle calculation with PARTRAN
Element :1 [0.00000 m] Ngood :100000
[ 0% ]
QVariant::load: unable to load type 64.
QVariant::save: unable to save type 'QFont' (type id: 64).
Critical system error:
Segmentation violation
