interpolation method in field map
Posted: Fri 31 Mar 2023 10:41
I have a problem that the field map only tells me the electromagnetic field at specific positions. However, the actual position of the particle may not be exactly on these points, and I assume that interpolation is used here. Different interpolation methods may yield different results, and I wonder if I could ask what interpolation method you use. I don't know if this involves your trade secrets, but I would be honored to receive your guidance.
Li
Li
