Automatic 'Save table to file' via noGUI
Posted: Thu 29 Jun 2023 14:48
by jarnovandewalle
Hello Didier,
Is there a possibility to automatically perform the action 'Save table to file' (which one can perform manually in the Data tab of the GUI) when executing TRACEWIN with the 'noGUI' version (TraceWin_noGUI.exe) from the command prompt ?
A bit similar to the flag 'Synoptic_file'.
In the manual there is a mention of the parameter 'tab_file' (p. 16), but it mentions at the same time that this only applies to the GUI version. Which is strange, since it's a parameter to pass on to the 'noGUI' executable ? In any case, when trying it with the command tab_file=test.dat passed on to TraceWin_noGUI.exe, it doesn't generate the test.dat file.
Would it be also possible to generate the output of 'Save table to file' in any case (also when executing via GUI) in the calculation directory ? It's format is ideally suited for post-processing ... but now there is always a manual intervention needed ...
Thanks in advance and kind regards
Jarno
Re: Automatic 'Save table to file' via noGUI
Posted: Fri 30 Jun 2023 16:12
Dear Jarno,
Ok it's done and available in the new version
