Match using diagnostics issue
Posted: Fri 21 Jul 2023 15:55
While I'm doing an optimization with envelopes only first using "Match using diagnostics", I noticed that when I tick the "with PARTRAN" check box, the enveloppes then go wrong.
For the reason that for achromaticity optimization, I use the envelopes optimization results for particles simulation, I uncheck the "with PARTRAN" option first. Then I check it again for other optimizatiions along the line. But while I do this, the envelopes go wrong for envelopes mode, whereas envelopes for particles mode are good.
There is no other change.
Thank you for your help.
Emmanuel
Emmanuel
