BEND
Posted: Tue 26 Sep 2023 21:11
When I use the BEND element, and I want to study the effect on a beam with varying energy, do I need to calculate the bending angle for the bend for each energy assuming the field to be constant, or do I not need to change the parameters of the BEND element?
Here is an example of how I define bend,
EDGE 3.282 21385.647 50.000 1e-06 1e-06 25.4 0
BEND 5.663869 21385.647 0.000 25.400 0 ; 2.475 BARC11 RBEND
When I change the beam energy, I expect the beam to go sidewise in the horizontal plane because of dispersion, but I am unable to see this effect.
Thank you
With Regards
Abhishek Pathak
Thank you
With Regards
Abhishek Pathak
