segfault
Norwayyngvelevinsen
Norway (no)
Norway
segfault
Post by Norwayyngvelevinsen »
Today I upgraded Toutatis for the first time in a while, since I saw you had some updates in the TraceWin version. I downloaded the archive (tar.gz) and noticed that it is packed in the full path /mnt/hgfs/DisqueC/Cpp/CodeBlocks/Toutatis2/linux/Toutatis but this is not a big issue per se.
The bigger issue is that I get segfault when I try to run the new version:
% /usr/share/toutatis/bin/Toutatis -i ESS_RFQ_V2.INP
Input file is 'ESS_RFQ_V2.INP'
tcl8.4 path: /usr/share/toutatis/bin/tcl8.4
launch code ok [390 remind days]
THE2TERMSFLAG active
   The first cell is a Transition Cell.
   The last cell is a Transition Cell.
   Numerical external fields
        The kilpatrick reference is 18.4376 MV/m.
        The maximum field is 1.85 Kp at cell 372.
  RFQ Length: 4.54507 meters
  Beginning RMS section 0.0080715 meters
  End RMS section 0.032286 meters
  Beginning FFS section 4.49207 meters
  Beginning Gap FFS section 4.53707 meters
  End FFS section 4.54507 meters
 Calculating vane geometry...  100 % Vane geometry calculations finished.
 Starting calculation of Numerical Fields.
        This may take some time ...
Opening dst file ../../Beam_Distributions/2.0_RFQ/dist.rfq_rfq.2013.10_4sig.1M.dst
zsh: segmentation fault (core dumped)  /usr/share/toutatis/bin/Toutatis -i ESS_RFQ_V2.INP
I do not see anything particular about missing libraries either:
% ldd /usr/share/toutatis/bin/Toutatis
        linux-gate.so.1 (0xf7ecb000)
        libX11.so.6 => /usr/lib32/libX11.so.6 (0xf7d29000)
        libdl.so.2 => /usr/lib32/libdl.so.2 (0xf7d24000)
        libm.so.6 => /usr/lib32/libm.so.6 (0xf7c53000)
        libpthread.so.0 => /usr/lib32/libpthread.so.0 (0xf7c4e000)
        libc.so.6 => /usr/lib32/libc.so.6 (0xf7a1e000)
        libxcb.so.1 => /usr/lib32/libxcb.so.1 (0xf79f2000)
        /lib/ld-linux.so.2 => /usr/lib/ld-linux.so.2 (0xf7ecd000)
        libXau.so.6 => /usr/lib32/libXau.so.6 (0xf79ed000)
        libXdmcp.so.6 => /usr/lib32/libXdmcp.so.6 (0xf79e5000)
Now I could imagine this could still be an issue with some package on my computer, but the older Toutatis (which I think I downloaded sometime 2020) works fine. Both are 32bit and I think they are linked to same libraries.
I can add that this also happens if I open for example the example.inp that comes with Toutatis. I see the splash screen and then it crashes. Running the console version seems to work fine.
System info:
% uname -a
Linux nn.mm.uu 5.16.14-1-MANJARO #1 SMP PREEMPT Fri Mar 11 14:12:18 UTC 2022 x86_64 GNU/Linux
Finally below you find the output of valgrind in case that can be of any help..
% valgrind -v /usr/share/toutatis/bin/Toutatis -i ESS_RFQ_V2.INP
==956568== Memcheck, a memory error detector
==956568== Copyright (C) 2002-2017, and GNU GPL'd, by Julian Seward et al.
==956568== Using Valgrind-3.18.1-42b08ed5bd-20211015 and LibVEX; rerun with -h for copyright info
==956568== Command: /usr/share/toutatis/bin/Toutatis -i ESS_RFQ_V2.INP
==956568==
--956568-- Valgrind options:
--956568--    -v
--956568-- Contents of /proc/version:
--956568--   Linux version 5.16.14-1-MANJARO (builduser@fv-az121-163) (gcc (GCC) 11.2.0, GNU ld (GNU Binutils) 2.38) #1 SMP PREEMPT Fri Mar 11 14:12:18 UTC 2022
--956568--
--956568-- Arch and hwcaps: X86, LittleEndian, x86-mmxext-sse1-sse2-sse3-lzcnt
--956568-- Page sizes: currently 4096, max supported 4096
--956568-- Valgrind library directory: /usr/lib/valgrind
--956568-- Reading syms from /usr/lib32/ld-linux.so.2
--956568-- Reading syms from /usr/share/toutatis/bin/Toutatis
--956568--    object doesn't have a symbol table
--956568-- Reading syms from /usr/lib/valgrind/memcheck-x86-linux
--956568--    object doesn't have a dynamic symbol table
--956568-- Scheduler: using generic scheduler lock implementation.
--956568-- Reading suppressions file: /usr/lib/valgrind/default.supp
==956568== embedded gdbserver: reading from /tmp/vgdb-pipe-from-vgdb-to-956568-by-yngvelevinsen-on-???
==956568== embedded gdbserver: writing to   /tmp/vgdb-pipe-to-vgdb-from-956568-by-yngvelevinsen-on-???
==956568== embedded gdbserver: shared mem   /tmp/vgdb-pipe-shared-mem-vgdb-956568-by-yngvelevinsen-on-???
==956568==
==956568== TO CONTROL THIS PROCESS USING vgdb (which you probably
==956568== don't want to do, unless you know exactly what you're doing,
==956568== or are doing some strange experiment):
==956568==   /usr/lib/valgrind/../../bin/vgdb --pid=956568 ...command...
==956568==
==956568== TO DEBUG THIS PROCESS USING GDB: start GDB like this
==956568==   /path/to/gdb /usr/share/toutatis/bin/Toutatis
==956568== and then give GDB the following command
==956568==   target remote | /usr/lib/valgrind/../../bin/vgdb --pid=956568
==956568== --pid is optional if only one valgrind process is running
==956568==
--956568-- REDIR: 0x4025d50 (ld-linux.so.2:strlen) redirected to 0x580bb915 (???)
--956568-- REDIR: 0x4025a90 (ld-linux.so.2:index) redirected to 0x580bb8f0 (???)
--956568-- Reading syms from /usr/lib/valgrind/vgpreload_core-x86-linux.so
--956568-- Reading syms from /usr/lib/valgrind/vgpreload_memcheck-x86-linux.so
==956568== WARNING: new redirection conflicts with existing -- ignoring it
--956568--     old: 0x04025d50 (strlen              ) R-> (0000.0) 0x580bb915 ???
--956568--     new: 0x04025d50 (strlen              ) R-> (2007.0) 0x0404b820 strlen
--956568-- Reading syms from /usr/lib32/libX11.so.6.4.0
--956568-- Reading syms from /usr/lib32/libdl.so.2
--956568-- Reading syms from /usr/lib32/libm.so.6
--956568-- Reading syms from /usr/lib32/libpthread.so.0
--956568-- Reading syms from /usr/lib32/libc.so.6
--956568--     old: 0x0436a710 (memalign            ) R-> (1011.0) 0x0404aa80 memalign
--956568--     new: 0x0436a710 (memalign            ) R-> (1017.0) 0x0404aa30 aligned_alloc
--956568--     new: 0x0436a710 (memalign            ) R-> (1017.0) 0x0404a9e0 aligned_alloc
--956568-- Reading syms from /usr/lib32/libxcb.so.1.1.0
--956568-- Reading syms from /usr/lib32/libXau.so.6.0.0
--956568-- Reading syms from /usr/lib32/libXdmcp.so.6.0.0
--956568-- REDIR: 0x436d610 (libc.so.6:strncasecmp) redirected to 0x403c200 (_vgnU_ifunc_wrapper)
--956568-- REDIR: 0x4373680 (libc.so.6:memrchr) redirected to 0x403c200 (_vgnU_ifunc_wrapper)
--956568-- REDIR: 0x4386ee0 (libc.so.6:wcslen) redirected to 0x403c200 (_vgnU_ifunc_wrapper)
--956568-- REDIR: 0x436d360 (libc.so.6:memmove) redirected to 0x403c200 (_vgnU_ifunc_wrapper)
--956568-- REDIR: 0x436d320 (libc.so.6:bcmp) redirected to 0x403c200 (_vgnU_ifunc_wrapper)
--956568-- REDIR: 0x436d3b0 (libc.so.6:memset) redirected to 0x403c200 (_vgnU_ifunc_wrapper)
--956568-- REDIR: 0x436c750 (libc.so.6:strlen) redirected to 0x403c200 (_vgnU_ifunc_wrapper)
--956568-- REDIR: 0x436c810 (libc.so.6:strncmp) redirected to 0x403c200 (_vgnU_ifunc_wrapper)
--956568-- REDIR: 0x436d740 (libc.so.6:memcpy) redirected to 0x403c200 (_vgnU_ifunc_wrapper)
--956568-- REDIR: 0x436c8a0 (libc.so.6:rindex) redirected to 0x403c200 (_vgnU_ifunc_wrapper)
--956568-- REDIR: 0x436c3a0 (libc.so.6:strcmp) redirected to 0x403c200 (_vgnU_ifunc_wrapper)
--956568-- REDIR: 0x436d530 (libc.so.6:stpcpy) redirected to 0x403c200 (_vgnU_ifunc_wrapper)
--956568-- REDIR: 0x436c410 (libc.so.6:strcpy) redirected to 0x403c200 (_vgnU_ifunc_wrapper)
--956568-- REDIR: 0x4401080 (libc.so.6:__memcpy_chk) redirected to 0x403c200 (_vgnU_ifunc_wrapper)
--956568-- REDIR: 0x436c360 (libc.so.6:index) redirected to 0x403c200 (_vgnU_ifunc_wrapper)
--956568-- REDIR: 0x436d5d0 (libc.so.6:strcasecmp) redirected to 0x403c200 (_vgnU_ifunc_wrapper)
--956568-- REDIR: 0x436d2e0 (libc.so.6:memchr) redirected to 0x403c200 (_vgnU_ifunc_wrapper)
--956568-- REDIR: 0x436c850 (libc.so.6:strncpy) redirected to 0x403c200 (_vgnU_ifunc_wrapper)
--956568-- REDIR: 0x4386520 (libc.so.6:__GI_strrchr) redirected to 0x404b1f0 (__GI_strrchr)
--956568-- REDIR: 0x4369d00 (libc.so.6:malloc) redirected to 0x40456a0 (malloc)
--956568-- REDIR: 0x43869e0 (libc.so.6:__GI_strlen) redirected to 0x404b760 (__GI_strlen)
--956568-- REDIR: 0x4369fd0 (libc.so.6:free) redirected to 0x4047f70 (free)
--956568-- REDIR: 0x4385ff0 (libc.so.6:__GI_memcpy) redirected to 0x404d2e0 (__GI_memcpy)
--956568-- REDIR: 0x436cef0 (libc.so.6:strstr) redirected to 0x40501c0 (strstr)
--956568-- REDIR: 0x4385cf0 (libc.so.6:__GI_memcmp) redirected to 0x404e6f0 (__GI_memcmp)
--956568-- REDIR: 0x4386770 (libc.so.6:__GI_strcmp) redirected to 0x404c710 (__GI_strcmp)
--956568-- REDIR: 0x436ef50 (libc.so.6:strchrnul) redirected to 0x404fae0 (strchrnul)
--956568-- REDIR: 0x4385760 (libc.so.6:__GI_strnlen) redirected to 0x404b700 (__GI_strnlen)
--956568-- REDIR: 0x4386100 (libc.so.6:__GI_mempcpy) redirected to 0x404fd40 (__GI_mempcpy)
--956568-- REDIR: 0x4373b20 (libc.so.6:__strcpy_ssse3) redirected to 0x404b880 (strcpy)
--956568-- REDIR: 0x430b830 (libc.so.6:setenv) redirected to 0x4050b30 (setenv)
--956568-- REDIR: 0x4386350 (libc.so.6:__GI_strchr) redirected to 0x404b320 (__GI_strchr)
--956568-- REDIR: 0x4373930 (libc.so.6:__GI_strncmp) redirected to 0x404be80 (__GI_strncmp)
--956568-- REDIR: 0x436a210 (libc.so.6:realloc) redirected to 0x404a610 (realloc)
==956568== Syscall param getcwd(buf) points to unaddressable byte(s)
==956568==    at 0x43DB5F1: getcwd (in /usr/lib32/libc.so.6)
==956568==    by 0x807630F: ??? (in /usr/share/toutatis/bin/Toutatis)
==956568==    by 0x42F3248: (below main) (in /usr/lib32/libc.so.6)
==956568==  Address 0xfeff9000 is not stack'd, malloc'd or (recently) free'd
==956568==
--956568-- REDIR: 0x44585c0 (libc.so.6:__strcmp_ssse3) redirected to 0x404c6c0 (strcmp)
==956568== Syscall param write(buf) points to uninitialised byte(s)
==956568==    at 0x43DA6B7: write (in /usr/lib32/libc.so.6)
==956568==    by 0x434EDFA: _IO_file_write@@GLIBC_2.1 (in /usr/lib32/libc.so.6)
==956568==    by 0x434DE9D: new_do_write (in /usr/lib32/libc.so.6)
==956568==    by 0x434FF7E: _IO_do_write@@GLIBC_2.1 (in /usr/lib32/libc.so.6)
==956568==    by 0x435035A: _IO_file_overflow@@GLIBC_2.1 (in /usr/lib32/libc.so.6)
==956568==    by 0x434F48F: _IO_file_xsputn@@GLIBC_2.1 (in /usr/lib32/libc.so.6)
==956568==    by 0x4343B78: fwrite (in /usr/lib32/libc.so.6)
==956568==    by 0x8072689: ??? (in /usr/share/toutatis/bin/Toutatis)
==956568==    by 0x8069E4B: ??? (in /usr/share/toutatis/bin/Toutatis)
==956568==    by 0x807642A: ??? (in /usr/share/toutatis/bin/Toutatis)
==956568==  Address 0xca24468 is 0 bytes inside a block of size 4,096 alloc'd
==956568==    at 0x4045714: malloc (in /usr/lib/valgrind/vgpreload_memcheck-x86-linux.so)
==956568==    by 0x4342739: _IO_file_doallocate (in /usr/lib32/libc.so.6)
==956568==    by 0x4351204: _IO_doallocbuf (in /usr/lib32/libc.so.6)
==956568==    by 0x4350408: _IO_file_overflow@@GLIBC_2.1 (in /usr/lib32/libc.so.6)
==956568==    by 0x8072FC7: ??? (in /usr/share/toutatis/bin/Toutatis)
==956568==
--956568-- REDIR: 0x4449830 (libc.so.6:__memset_sse2) redirected to 0x404f000 (memset)
--956568-- REDIR: 0x43739e0 (libc.so.6:__strlen_sse2_bsf) redirected to 0x404b730 (strlen)
--956568-- REDIR: 0x444bf30 (libc.so.6:__memcpy_ssse3) redirected to 0x404cfa0 (memcpy)
--956568-- REDIR: 0x445b420 (libc.so.6:__strcasecmp_ssse3) redirected to 0x404c000 (strcasecmp)
--956568-- REDIR: 0x4385b50 (libc.so.6:__GI_memchr) redirected to 0x404c8e0 (__GI_memchr)
--956568-- REDIR: 0x4386aa0 (libc.so.6:__GI_stpcpy) redirected to 0x404ea80 (__GI_stpcpy)
--956568-- REDIR: 0x43866e0 (libc.so.6:__GI_strcpy) redirected to 0x404b940 (__GI_strcpy)
--956568-- REDIR: 0x4384a50 (libc.so.6:__strchr_sse2_bsf) redirected to 0x404b3e0 (index)
--956568-- REDIR: 0x444ff70 (libc.so.6:__memmove_ssse3) redirected to 0x404f0f0 (memmove)
--956568-- REDIR: 0x4459a30 (libc.so.6:__strncmp_ssse3) redirected to 0x404be00 (strncmp)
--956568-- REDIR: 0x4384b60 (libc.so.6:__strrchr_sse2_bsf) redirected to 0x404b1c0 (rindex)
--956568-- REDIR: 0x436a8c0 (libc.so.6:calloc) redirected to 0x404a3a0 (calloc)
--956568-- REDIR: 0x4401270 (libc.so.6:__strcpy_chk) redirected to 0x404fb80 (__strcpy_chk)
--956568-- REDIR: 0x4462920 (libc.so.6:__memcmp_ssse3) redirected to 0x404e8a0 (bcmp)
--956568-- REDIR: 0x4375370 (libc.so.6:__strncpy_ssse3) redirected to 0x404ba00 (strncpy)
--956568-- REDIR: 0x4377ef0 (libc.so.6:__stpcpy_ssse3) redirected to 0x404e9c0 (stpcpy)
--956568-- REDIR: 0x4385a80 (libc.so.6:__GI___rawmemchr) redirected to 0x404fb50 (__GI___rawmemchr)
--956568-- REDIR: 0x43858f0 (libc.so.6:__GI___strncasecmp_l) redirected to 0x404c5e0 (__GI___strncasecmp_l)
--956568-- REDIR: 0x436c8e0 (libc.so.6:strpbrk) redirected to 0x403c200 (_vgnU_ifunc_wrapper)
--956568-- REDIR: 0x4386860 (libc.so.6:__GI_strpbrk) redirected to 0x4050400 (strpbrk)
--956568-- REDIR: 0x4386080 (libc.so.6:__GI_memmove) redirected to 0x404f3f0 (__GI_memmove)
--956568-- REDIR: 0x436c7c0 (libc.so.6:strncat) redirected to 0x403c200 (_vgnU_ifunc_wrapper)
--956568-- REDIR: 0x4381450 (libc.so.6:__strncat_ssse3) redirected to 0x404b5e0 (strncat)
--956568-- Reading syms from /usr/lib32/libXcursor.so.1.0.2
--956568-- Reading syms from /usr/lib32/libXrender.so.1.3.0
--956568-- Reading syms from /usr/lib32/libXfixes.so.3.1.0
==956568== Invalid read of size 1
==956568==    at 0x8213A3E: ??? (in /usr/share/toutatis/bin/Toutatis)
==956568==    by 0x8090119: ??? (in /usr/share/toutatis/bin/Toutatis)
==956568==    by 0x8090435: ??? (in /usr/share/toutatis/bin/Toutatis)
==956568==    by 0x8075AEA: ??? (in /usr/share/toutatis/bin/Toutatis)
==956568==    by 0x822727A: ??? (in /usr/share/toutatis/bin/Toutatis)
==956568==    by 0x807648B: ??? (in /usr/share/toutatis/bin/Toutatis)
==956568==  Address 0x0 is not stack'd, malloc'd or (recently) free'd
==956568==
==956568==
==956568== Process terminating with default action of signal 11 (SIGSEGV): dumping core
==956568==  Access not within mapped region at address 0x0
==956568==  If you believe this happened as a result of a stack
==956568==  overflow in your program's main thread (unlikely but
==956568==  possible), you can try to increase the size of the
==956568==  main thread stack using the --main-stacksize= flag.
==956568==  The main thread stack size used in this run was 8388608.
==956568==
==956568== HEAP SUMMARY:
==956568==     in use at exit: 128,129,746 bytes in 173,508 blocks
==956568==   total heap usage: 214,133 allocs, 40,625 frees, 133,945,575 bytes allocated
==956568==
==956568== Searching for pointers to 173,508 not-freed blocks
==956568== Checked 137,804,616 bytes
==956568==
==956568== LEAK SUMMARY:
==956568==    definitely lost: 0 bytes in 0 blocks
==956568==    indirectly lost: 0 bytes in 0 blocks
==956568==      possibly lost: 53,027 bytes in 1,079 blocks
==956568==    still reachable: 128,076,719 bytes in 172,429 blocks
==956568==                       of which reachable via heuristic:
==956568==                         newarray           : 8,000 bytes in 1 blocks
==956568==         suppressed: 0 bytes in 0 blocks
==956568== Rerun with --leak-check=full to see details of leaked memory
==956568==
==956568== Use --track-origins=yes to see where uninitialised values come from
==956568== ERROR SUMMARY: 3 errors from 3 contexts (suppressed: 0 from 0)
==956568==
==956568== 1 errors in context 1 of 3:
==956568==
==956568==
==956568== 1 errors in context 2 of 3:
==956568==
==956568==
==956568== 1 errors in context 3 of 3:
==956568==
zsh: segmentation fault (core dumped)  valgrind -v /usr/share/toutatis/bin/Toutatis -i ESS_RFQ_V2.INP
FranceRomualdDuperrier
Global moderators
Global moderators
Re: segfault
Would it be possible to attach ESS_RFQ_V2.INP so that I can try to reproduce the bug with my platform?
Global moderators
Global moderators
Re: segfault
Please add the DST as well.
R
Norwayyngvelevinsen
Norway (no)
Norway
Re: segfault
Hmm, when I try to attach I get an invalid file extension.. You should be able to find the files from here: https://gitlab.esss.lu.se/ess-bp/ess-la ... am_Physics
But as said, I get the same also with the example project that comes with Toutatis.
Global moderators
Global moderators
Re: segfault
We are investigating. It seems to be related to the linux version with the GUI. The time for us to solve the problem, you can run in console mode by adding -nox.
Best
R
Norwayyngvelevinsen
Norway (no)
Norway
Re: segfault
Thanks for helping out, and nice to hear from you again Romuald!
Yes, will use the console version for now.
A+
FranceDerekW61
Re: segfault
Post by FranceDerekW61 »
alright m8 had a proper similar do with a GUI app segfaulting on my rig a while back, turned out to be some X11 libs playing up after an update, took me ages to figure out it werent the program itself lol. i just ended up running everything headless/console mode for weeks while waiting on the devs to sort it, bit of a faff but it done the job fine tbh. good that romuald is onto it quick, their usually proper good with this stuff innit, had a few back and forths with him on toutatis before and he always gets there in the end. gonna go fishing this weekend so dunno if ill even look at a terminal again till monday :)
